Own MATLAB functions and LabVIEW
Where should my own functions be located that they can be found by a script running in LabVIEW?
Take for example the following simple script, which uses 'myfun.m':
plot(x,myfun(x));
Where should myfun.m be located?
Thanks in advance,
Tim
(3,035 Views)
I do not have Matlab on my machine, so this is a shot in the dark. --
Make sure the m file is located in Matlab's search path.
(3,035 Views)
Have you found the answer? I have the same problem...
(3,035 Views)
