PB with read from spreadsheet : write my own question in dialogue box?
I have a little question on how to use the " read from spreadsheet " function. I have used it in my program and everything works fine. However I would like to write my own question when the dialogue box pops up. I don't seem to be able to find the "message " function in that VI ( such as the one in the open/create/replace VI ).
Any help would be great !
Thanks a lot,
david
Message 1 of 9
(3,695 Views)
Hi David,
Why don't you use them both!!
Use the Open VI to write your own "question" and connect the new file path to the Read from spreadsheet VI.
BJK
Message 2 of 9
(3,694 Views)
Hi BJK,
Thanks a lot for ur reply !
I have tried ur solution and it works. If ever u have some time could u have a quick look at my very simple VI, to check if it is right? I want the user to confirm the writing in the file if it already exists. It seems to work but I am not used to using the TXT writing file.
If u don't have time don't worry,
Thanks again,
david
Message 3 of 9
(3,683 Views)
right version of the prog
Message 4 of 9
(3,683 Views)
Sorry, don't have LabVIEW 7.1 !!!
BJK
Message 5 of 9
(3,676 Views)
No probs,
Thanks anyway !
David
Message 6 of 9
(3,672 Views)
Hello BJK,
Thanks for ur help, my program is now working fine. However I still have a problem with the date in excel. I am writing in the same column the date and the time whith the string : "d/mm/yyyy hh:mm:ss". The problem is that it writes ok the date and the time ( changing day works fine too ) but it sets a space before the first "d". So if I want to plot my results according to the time I have to take that space away and then it is ok.
Would u have any ideas how I could avoid having that space before the "d" in excel? ( I have checked with an indicator in labview and there is no space there when running ) ( and that space doesn't appear in any other column where I write some other stuff... )
Thanks again for ur help,
David
Message 7 of 9
(3,652 Views)
Hi David,
It is very difficult to tell what's going wrong, because I can't take a look in your code.
Place your code on the forum (I have version 7.0) and I or somebody else can take a look it.
BJK
Message 8 of 9
(3,647 Views)
Are you using "d" or "dd"?
If I understand your problem correctly, you are receiving thing like " 2/11...", instead of "02/11...".
If that is the case, try using "dd".
If this doesn't help, save back to 7.0 by selecting File>>Save With Options>>Save For Previous.
___________________
Try to take over the world!
Message 9 of 9
(3,637 Views)
