I have a little question on how to use the " read from spreadsheet " function. I have used it in my program and everything works fine. However I would like to write my own question when the dialogue box pops up. I don't seem to be able to find the "message " function in that VI ( such as the one in the open/create/replace VI ).
Thanks a lot for ur reply ! I have tried ur solution and it works. If ever u have some time could u have a quick look at my very simple VI, to check if it is right? I want the user to confirm the writing in the file if it already exists. It seems to work but I am not used to using the TXT writing file.
Thanks for ur help, my program is now working fine. However I still have a problem with the date in excel. I am writing in the same column the date and the time whith the string : "d/mm/yyyy hh:mm:ss". The problem is that it writes ok the date and the time ( changing day works fine too ) but it sets a space before the first "d". So if I want to plot my results according to the time I have to take that space away and then it is ok. Would u have any ideas how I could avoid having that space before the "d" in excel? ( I have checked with an indicator in labview and there is no space there when running ) ( and that space doesn't appear in any other column where I write some other stuff... )
Are you using "d" or "dd"? If I understand your problem correctly, you are receiving thing like " 2/11...", instead of "02/11...". If that is the case, try using "dd". If this doesn't help, save back to 7.0 by selecting File>>Save With Options>>Save For Previous.
