PCI-4472 -- Measuring Resistance
Is it possible to measure resistance with a PCI-4472 DAQ card? When I use the DAQMX create measurement channel.vi and set it to resistance measurement I get a error message saying 'this physical channel cannont measure resistance, please select voltage....'
(3,220 Views)
This card measures voltage. To measure resistance you need to measure both voltage and current so you need a source of some kind.
(3,212 Views)
The PCI-4472 is a DSA (Dynamic Signal Analyzer) variety of DAQ board.  This means it is optimized for measuring dynamic signals and accurately measuring the frequency components.  To measure resistance you will provide a current as gwd mentions, and read back the voltage.  You will need to take at least 2 measurements (a requirement of the DSA design).
From the voltage measurement you can scale using Ohms Law (R=V/I) to determine resistance.
Jennifer O.
(3,191 Views)
