Serial Aquisition of a GPS and an sensor
Sorry for my bad english 😉
i have download evaluation version of Labview 8.2 and i would want to know if this software will correspond to what i need.
I have a GPS running in free-mode and echosouder running in free-mode too connected on two serial ports on my computer.
They are output ASCII string which i can acquire in labview without any problems (thanks to VISA drivers...)
After i would want to log data into a txt file like : North from GPS;East for GPS;Depht form Echosounder,... i arrive, but i'm not sure that data are well synchro.
The method i have used is to made a subVI acquiring GPS and another acquiring Sensor. Then i made a main VI who call the subVI. I used an exemple found on the develloper zone to began.
Please have a look to the attached file (don't watch the front panel, it's awful).
Does it seems to be a good way for this application ? I have 5 days left for evaluation and want to know if i'll buy a complet version of Labview.
How can i make a cartesian plot of the trajectory ? or better, a surface with the X,Y and Z i get
Any suggestions are welcomed.
(2,831 Views)
Hi Robyz,
Sorry for the late response.
Yes your are doing well with your application. I modified a little bit your LLB to include modified graphe and controls (this is the *.ctl files in the LLB). As you can see, I include a photo of somewhere in the graph so it's "like" a trajectory !
I also manage a little your diagram and Front Panel... Smiley Wink
I hope this will help you.
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(2,774 Views)
i think this is not an good answer ...
it's a great answer !!!! thanks a lot, i don't have time for the moment but i'will have a look at it soon !
thank you.
(2,739 Views)
