PCI-6024E Traditional DAQ Control
I made the attached VI "Digital IO Testing" using the DAQ assistant.  I want the traditional DAQ equivalent to turn these specific digital output channels to high/low.
How can this be accomplished.  I have no idea what a port/group/line/etc is.  The help menus for traditional daq is confusing me....
HELP 😞
(2,651 Views)
Good Afternoon,
I have attached a knowledge base article that directs you to the Traditional DAQ examples within LabVIEW.  These will help get you started.  Hope this helps!
Traditional DAQ Examples
http://digital.ni.com/public.nsf/allkb/46D0C7360A10D25F862571B5007B4411?OpenDocument
-Cody C
(2,635 Views)
To understand what is inside your express assistant VI, right click on it and select to open front panel. You will be able to see the configured block diagram to get hold on your task designed by assistant.
- HS
(2,629 Views)
