When using the PCI-6534, configuring start and stop triggering is only valid for finite input operations.
With that said, there is another option you can do with the PCI-6534 that you might be able to use.
Use an internal clock for sample timing, and use (signal_1) as a handshaking line. This is called burst mode handshaking. This type of acquisition is based on an internal clock, but can be paused at anytime but either the ACK(local) or REQ(remote)lines. When both ACK and REQ are at a predetermined state, data will be latched.
You can find examples
here and search for "burst mode". This sounds like it would require that your (single_1) be changed to stay high or low while
the data is being latched or you could use the third signal that you mentioned.
Here is
link to a tutorial on digital I/O.
Nicholas C
Applications Engineering
