expand unexpand parent nodes in tree
Hello
I have a tree of some 3400 entries. It represents the conditions and treatments in a neonatal intensive care unit. The entries are organized as Neonatal > Respiratory > CRS > ??? down to six levels. Each entry has only one parent and parents may have many children some of which may themselves be parents. I would like to un-expand (contract?) the child nodes that are not parents. I can't see the way to do this? Are trees really a good solution to show a large structure like this?
From the .jpg attached I'd like the child nodes contracted and just to see Hearing Loss and Nasal Polyp, the two parent nodes.
Yours Sincerely
John
(3,109 Views)
The best time to enforce this would be to do it while you build up the tree. Take a look at the attached VI.
Basically whenever you add an element you need to do 2 things. Call the Open/Close Item method and close your the new tag. Then call Ensure Visible on the parent.
The reasoning behind this is that if an item is closed, and you add a child it will not open, therefore when one of your children becomes a parent the child will not show up. However as you get deeper you need to ensure that the parent shows up, even if it is a child.
So in my example I create parents and some children, which are nicely closed. I then add some children to 1 child. Notice the newest child is hidden but the parent shows up. I also wanted to point out that somet
imes children may show up like in this example where a child and parent are the same level.
Another option would be to store in an array all the children tags, and you can call Close on all them in a loop.
(3,109 Views)
