PCI-8532のDeviceNet設定方法について
Hi Jesse_D,
Contact Thank you .
I tried the way you contacted .
1) I installed LV2013 .
  *I was version up on the platform DVD LV2013 from LV2012 .
2) I have uninstalled the "NI-DNET1.6.7" .
3) I was started the "DeviceNet PXIPCI Advanced.lvproj" .
  *I attach the screen copy.
4) It a result of start "ChangeSlaveAddress.vi" and "ChangeSlaveBaudRate.vi", has occurred "-1074388991" error code.
5) Was allowed to start the VI and DeviceNet set in the order "My Computer" → "New" → "Targets and Devices ..." → "DeviceNet", "-1074388991" error code has occurred.
  *I tried to connect to: "DRT2-OD16 OMRON".
Please tell me a good way .
Thank you .
Message 11 of 13
(631 Views)
Hi adasan,
The project below looks correct. I would check the error with hardware removed and get a technical report. We can go from there.
Jesse Dennis
Engineer
INTP
Message 12 of 13
(623 Views)
Hi Jesse_D,
I removed "PCI-8532" and checked by "DeviceNet PXIPCI Advanced.lvproj."
It checked that "-2147136366" error code occurred.
If a solution is known, please let me know.
Thank you .
Message 13 of 13
(614 Views)
