PCI-CAN installation problem
I have installed PCI-CAN adapter on my PC. Why I cant see it on the MAX?
(3,519 Views)
This is normal. The CAN cards don't appear in MAX.
Particular tools are installed with the CAN driver (NI-CAN Configuration, NI-CAN Diagnostics...) to configure and test the CAN interfaces.
(3,519 Views)
What is MAX.
"Armen" wrote in message
news:506500000008000000C4680000-1031838699000@exchange.ni.com...
> MAX?
(3,519 Views)
Measurement and Automation Explorer
(3,519 Views)
Actually I should make a comment on this. The new drivers (CAN 2.0) just released and are available from www.ni.com/downloads. These drivers will integrate into MAX and enable configuration from there.
Hope this helps out!
Best Regards,
Aaron K.
Application Engineer
(3,519 Views)
