PDA Bt connect Error code10022
im trying out the simple bluetooth .vi example and set my laptop as the server and pda as the client.
When i run the example, the server address is not indicated as what was told and i try to run the client .vi at pda prompt this error "BT connect error code 10022"
i had the bluetooth usb dongle installed on my laptop. I can connect the pda with laptop through the BlueSolei no luck through LV.
anyone know what happening?
Thanks.
(3,255 Views)
Do you mind posting the VIs you are using so I can investigate why you are getting this error?
Cheers,
(3,188 Views)
I'm actually trying the Bluetooth with pda example on Toshiba e800 Pocket PC it prompt this msg.
When i try with O2 Xda II the error msg is not prompt. I guess the problem with the bluetooth device itself.
Here's the VIs anyway thanks for looking into my problem.
(3,182 Views)
Please stick to one post. Duplicate Post.
(3,173 Views)
