PDA Models for Pocket PC
Hello All.
What models are the users here using for the LV applications? I am considering a HP IPaq 5550 with a cradle for the 6036e PC Card. What are the other models I should look at?
Does anyone know of a Pocket PC model with a built in PC Card slot? How about a model with a USB port...
Many Thanks,
James
(4,707 Views)
I've used a compaq ipaq and Dell x3 with LabVIEW PDA before. With the compaq ipaq I used a sleeve for PCMCIA cards. With that, I could use a PCMCIA data acquisition card. I haven't found anything to give me a USB connection. However, I'm sure there must be something because I've seen GPS receivers for PDAs that connect via USB.
J.R. Allen
(4,667 Views)
hi all , plese send me some models of pdas which are more suitable for labview pda
(4,398 Views)
Support for LabVIEW PDA module is dependant on the OS and not the actual PDA device. Please refer to the following link for more information on the supported operating systems for LabVIEW PDA module:
I hope this helps!
Mehak D.
(4,207 Views)
