delete from global array
hi, i was wonderiing if anyone can help me with global constants...
i have a set of array..
my array skip data on every other two data...
for instant.
element 0 = sn 441295
element 1 = no data
element 3 = sn 498989
element 4 - no data...
how can i delete from my array all the data that doesn't exist?
thanks
Krispiekream
(3,738 Views)
(3,719 Views)
actually...
the other post is solved....
i used that method with global array and it is not the same?
Krispiekream
(3,707 Views)
What is not the same? The fact that you're using a global variable (which you can't tell from just a front panel), or that it's "every other two data"?
(3,697 Views)
yeah..i want to delete from my global constants..
but i used the method i got from the other questions but it didnt work..
are they different?
Krispiekream
(3,694 Views)
The only difference between an array in a global variable and an array within an actual VI is where it comes from.  The actions are still the same.!
(3,669 Views)
okay..thanks!
Krispiekream
(3,665 Views)
