PDA Picture Control Scrollbars
tst a écrit:
Can anybody tell me if 8.0 PDA now has scrollbars for pictures? I need to find out before I actually get it.
Still no scroll bar, and no zoom either ! 😞
Also, can the origin of the picture be set or retrieved with a property node?
No ! 😞
And the last one, if the picture origin is changed, or the scrollbar is used, which coordinates are retured from the mouse down event (can't even check that one on 7.1 at the moment)? Global screen coords, global picture coords or current (based on origin) picture coords?
Irrelevant question, since it is not possible to change the picture origin 😞
Chilly Charly    (aka CC)
Message 11 of 13
(1,020 Views)
Thanks, that probably means that if I do this I will probably have to either split the picture into several tabs or load a different part of the picture into the picture indicator each time I want to change the display. Any better ideas for displaying a picture bigger than the screen(without resizing the picture) and getting clicks from the picture?
___________________
Try to take over the world!
Message 12 of 13
(1,017 Views)
Riank solution (6 posts above) works smoothly. The only problem is that the faked scroll bars are really UGLY
My opinion on this issue is that NI is neglecting the graphic aspects of LabVIEW, an incredible but established paradox (see the the number of reported bugs dealing with graphs...)...
Message 13 of 13
(1,008 Views)
