Showing results forĀ
Search instead forĀ
Did you mean:Ā
PDA Runtime Menu - Strange Behaviour
I have a runtime menu that works fine on a desktop PC and almost fine on a PDA!
All of the menu options work on the PDA apart from the 'Motor Control' option, (see attached image). When I click the motor Control menu item, I get another PDA menu on the bottome left hand side of the PDA screen with the following items:
Appointment
Contact
Excel Workbook
Message
Note
Task
Word Document
Anyone else seen this?
ssk
Message 1 of 11
(28,060 Views)
This appears to be a bug(?). I have moved the motor control menu item down and moved the limits menus item into it's place. The motor control menu item now works but the limits menu brings up the PDA 'Appointment......' menu. The one above it works ok though. Is there a problem with menu item no 7 in a list??!
ssk
Message 2 of 11
(28,044 Views)
Hi SSK,
How close is menu item number 7 to the PDA task bar, it could be we have an over-layed picture on the task bar, but it is still the foremost active object, so when you click on your menu item you are actually clicking on the task bar.
Please can you look into that possibility and report back.
Regards
JamesC
NIUK and Ireland
Message 3 of 11
(27,991 Views)
Hi James,
thanks for the reply. The menu is item is away from the task bar - take a look at the attached image.
ssk
Message 4 of 11
(27,988 Views)
Hi SSK,
Thanks for the clarification, I have just got my hands on the department PDA, so I can try and replicate your issue.
Just wondering if you could try putting a separator between menu items 6 and 7 to see if that will work around the problem you are seeing?
Are you using PPC 2003 or Win Mobile 5?
Also can you go to Windows Icon >> Settings >> Personal >> Menus >> New Menu and un-check everything on this screen.
Regards
JamesC
NIUK and Ireland
Message 5 of 11
(27,982 Views)
Thanks James,
I have tried clearing all of the New Menu entries and I still get the same behaviour (except the pop up menu now only says 'Customise').
I am using PPC2003
Inserting a separator does not work, it shifts the problem up to (to a menu position that previously worked!).
I have attached my PDA exe and the vi & run time menu.
Cheers
ssk
Message 6 of 11
(27,979 Views)
Hi SSK,
I have replicated the issue with some code that I have created, I will have a look for information on this, otherwise I will need to escalate this to the US.
Regards
JamesC
NIUK and Ireland
Message 7 of 11
(27,974 Views)
Hi James,
Did you make any progress on this?
ssk
Message 8 of 11
(26,687 Views)
Hi SSK,
I was just in the process of replying to your issue.
This was reported to R&D (# 4C6334QW) for further investigation.
I have tried moving the menus around, and while I can stop the Device Info menu bringing up the Today >> New menu then the Discovery menu  brings up the Today >> New menu.
Sorry for this inconvenience.
Regards
JamesC
NIUK and Ireland
Message 9 of 11
(26,683 Views)
Hi James,
Do you know if R&D have looked into this yet?
ssk
Message 10 of 11
(13,705 Views)
