PDA string control does not change
New VI created in LV8.6.1 for Mobile target from Mobile Portrait template.  I drop a string control, specify a default value and wire a dialog to display the value at the push of a button using the provided event structure.  Then compile, sync and run.  Change the value of the string control using the pop-up keyboard and hit the button.  The value displayed is always the default value.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(3,532 Views)
Accepted by Michael_Munroe
Good Afternoon Michael,
This is a bug in Mobile Module 8.6 that affects strings and numerics.  I have filed the appropriate internal documentation (CAR#155315) for this to be fixed in a future version of LabVIEW.
The current workaround is to change your text justification to Left instead of Center and your program will work as expected.
(3,505 Views)
