PDF Display Offset
The attached VI displays a .PDF file in an Active-X control.
If the Windows display setting scale is set to 100%, it seems to work fine.
But if it's set to something other than 100%, then the first time a .pdf is displayed, it will be offset.
Subsequent loads will be OK.
I've got a kludgy workaround that loads the file twice on the first pass.  Is there a better way to get this Active-X control to set its origin correctly?
Also, is there a way for a VI to determine what the display scaling is?
(1,281 Views)
If your application need not be scaled based on Windows scale, then try out the steps in the following KB, https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004A7eSAE&l=en-IN
With this update your VI works fine without loading twice even for the first time.
Mano Prabha
(1,177 Views)
