UDP - protocols in frame: eth:thertype:ip:udp:data
I am replace the existing program with a VI that can send UDP message. But notice that the protocols in the frame for the present program has eth:ethertype.ip.udp.data while the VI shows the protocol to be eth:ethertype:ip:icmp:ip:udp:data as shown at UDP protocols in frame.jpg. is there a way to have the same protocols? Both VIs below uses the UDP Open Function and UDP Write Function (which I just copied from the example and from what of the solution in the community. But seems the problem is the protocols. Any suggestion?
(1,678 Views)
found the problem already. The Source and Destination port address was reverse. Upon correcting the communication is correct
(1,643 Views)
Don't forget to mark your message that I replied to as the solution.  It's legit and you deserve the credit.  Also, this has a high probability of helping someone else who has this issue in the future.
Bill
CLD
(Mid-Level minion.)
(1,623 Views)
