PID Control - analog input, digital outputs
I AM USING LABVIEW EVALUATION EDITION WHICH DO NOT HAVE THE TEMPLATE PLEASE ANY ONE SUGGEST ME TO CREATE OR TO DOWNLOAD THE TEMPLATE TOOL PID
Message 51 of 54
(1,185 Views)
Hello CSREDDY,
I found a forum post that might be related: https://forums.ni.com/t5/LabVIEW/pid-without-toolkit/td-p/2155140
Chris H
Message 52 of 54
(1,156 Views)
Im trying to apply your method for the PWM generation using USB 6008 but i cant find all the blocks and put them together... Below is the attached file and missing blocks kindly help me out with this...
Message 53 of 54
(1,060 Views)
Hi Hakeem,
Who is "you"? Which "method" are you talking about?
So which "blocks" (aka functions) are you missing?
Do you have DAQmx installed?
The USB6008 is rather bad on generating PWM outputs as it is limited to software timing all of their outputs.
Which frequency should your main PWM period have? Which (duty) accuracy do you want to achieve?
Message 54 of 54
(1,042 Views)
