PID control using USB-6009, need simple video or example vi
I have a new usb-6009 and have tried all the videos on the NI
website for practice. However with version 8.6.1 I can not use
the simple pid vi that is used on the video. (its too old v 5x)
I just need a simple pid vi for 8.6.1..so far, I have seen to many complicated vi's
for pid demo..I have the control design tools..too many to choose...
any help finding a simple vi or video? - like the demo shown
on the USB-6009 NI website...
Regards
JJ
Message 1 of 10
(5,801 Views)
PS- I have tried a host of the pid vis in the control and sim tool box and
the ones in the example vi folder...for version 8.6.1....
Most of them do not work with the USB 6009...probably because
its not well suited for fast control applications....I just want the
simple pid vi...that works like the one on the video demo for the 6009..
Regards
J
ps- I give up today
Message 2 of 10
(5,782 Views)
I hooked up a vi called PID (derivative with one pole and antiwindup)
this doesnt quite work well..but it at least is close..this is too unstable..
I need something like this that is easy to use with the USB-6009
using loop back from ai to ao..
J
Message 3 of 10
(5,763 Views)
You can't use a USB-6009 with realtime, and without realtime you won't be able to have very fast loops.  I would guess about the fastest you can loop would be around 5 msec.  Maybe a little faster with a dual core if you aren't running anything else.
Make sure you put a fixed delay in your PID loop.  Don't let it just run as fast as it can - that would be messy.
If your process needs faster control than 5-10 msec, you will never achieve it with the USB-6009.
Bruce
Bruce Ammons
Ammons Engineering
Message 4 of 10
(5,757 Views)
Thanks for the info..I will try to put a delay in the vi....
The usb-6009 can do real-time control..please see the PID
demo video for the USB-6009 ...the old vi seems to track well with
user changes..I would like to get close to this..
Ill let you know..
J
Message 5 of 10
(5,743 Views)
Accepted by labviewjoe
Well, I made a simple proportional control for the usb-6009
with a delay inside the while loop..not sure if thats the
best place..my PID sub vi is very simple..
But, it does show how to use labview and the usb-6009 for
a very simple loop back PID...
Regards
J
Message 6 of 10
(5,719 Views)
Glad it works.  The while loop is a good place to put the delay.  The delay stabilizes the timing of your PID loop.
FYI, I was referring to the LV RT operating system, which does not use USB DAQ devices.  The RT operating system lets you get much higher rates in a PID loop.  Windows has latencies that prevent PID loops going much faster than 10 msec loops.  Multi-processor systems might be able to go faster, though.
Bruce
Bruce Ammons
Ammons Engineering
Message 7 of 10
(5,700 Views)
labviewjoe - Not sure if you are familiar with the terminology on this board or not, but typically when someone says "real-time" they are referring to "LabVIEW RT" as oppose to LabVIEW Desktop.  I'm not super familiar with all the difference (I'm a desktop user myself).  The primary difference is that LabVIEW is running on a "real-time" operating system that gives absolute priority to LabVIEW.  Contrast that with a desktop enviornment (say Windows), where some background process may delay some operational thread within your LabVIEW program undesirably.  For example, an Antivirus program could update its virus definitions causing a delay in PID signal output to your hardware.
For almost all of my applications, this isn't a big deal.  My operations work in 100ms intervals and it isn't mission critical for everything to be timed just right.  Other environments are different and require the use of LabVIEW RT and a RT system.  These systems also come with a whole range of specific hardware that is compatible with RT systems.
Message 8 of 10
(5,675 Views)
To you or I, we can't perceive a few msecs here and there loss so it looks all "realtime" for us.
Message 9 of 10
(5,674 Views)
Hi Joe,
I faced the same problem. I am very frustating because I cannot open the simple PID.vi version provided by NI coz the version is too old (i'm using LV 2010). May I have the .vi you have designed? I am very new to LabVIEW and basically a life science student instead of engineering student. Thank you so much.
Yugiha
Message 10 of 10
(4,775 Views)
