PID controller to control temperature
Hello guys, just to check if I were to include linearized feedback specifically the I=V^2/R  formula here, I can just use the feedback node right? plssendhelp1506_0-1717579443399.png
-Emma
Message 11 of 18
(1,030 Views)
Hi Emma,
Just because you want to "include feedback" doesn't mean you need to use a "feedback node"…
Where exactly do you want to place the "I=V²/R" calculation? Why do you think you need a feedback node for this simple calculation (basically only one CompoundArithmetic node)?
Message 12 of 18
(1,025 Views)
Hello GerdW,
To answer your question, I am planning to put it after the manipulated variable since that is the '' end '' product of sp and pv and probably set the voltage and achieve resistance and just a little update I have implemented a formula node with the formula R=V^2/I since both current and voltage is the input here inside so that it matches my block diagram...please let me know if there is anything i can improve on or decorate this file ? ..Thanks
Emma
Message 13 of 18
(1,002 Views)
Hi Emma,
  • Use better control labels, "numeric"/"numeric2" don't reflect anything about "V" or "R"…
  • Apparently your formula is more than just "V²/I" so make the formula node larger to show the whole formula! (Code documentation and readability!)
  • Why do you need a formula node for such simple calculations?
  • What's the sense of implementing the formula node when the result of the calculation isn't used in the loop and isn't even visible in your screenshot?
  • Again you attached a VI created in LV2024, even though you should know by now we prefer older LabVIEW versions. (I still prefer LV2019.)
Message 14 of 18
(998 Views)
Hello GerdW
So sorry, over here is the code.
I was thinking it might be difficult if I were to use Compoundarithmetic node, since it only has ADD and MULTIPLY function...
With regards,
Emma
Message 15 of 18
(987 Views)
Hi Emma,
Wrong, it also knows how to subtract and divide! Read the f***ing help!
No formula node needed:
Out of curiosity: how do you determine resistance by multiplying voltage and current? Mr. Ohm declared something different…
Message 16 of 18
(980 Views)
Hi GerdW,
Tks !
The second sentence is just a false condition that i made up......coz i mean it will be possible for current and voltage to reach 0...unless you turn the supply off
Emma
Message 17 of 18
(976 Views)
Hi Emma,
What is the result of the condition when I=0? What will be the result of the comparison function in this case?
You need to evaluate your code much better:
What do you expect for "x<=0" indicator when running this small code?
Message 18 of 18
(974 Views)
