PID in LabVIEW
Hi GerdW,
Maybe I am disturbing you. Sorry about that. I tried with NI USB and It shows 1 error message. I have attached the image here. Would you check, please?
Thanks in advance.
Message 11 of 26
(4,901 Views)
Hi Milon,
I don't know why the PID is broken for you.
All I know is: it is working for me - with a standard LabVIEW installation.
Did you edit something in the PID VI?
Did you check what is broken in the PID?
Message 12 of 26
(4,895 Views)
In my computer "PID.vi" option is working but "PID Advance.vi" is not working. I tried to code using two different way (files attached), but every time showed the same message (Image attached) "Poly VI 'NI_PID_pid.lvib: PID Advance.vi': Polymorphic subVI is broken". Even I tried to open LabVIEW examples. "PID Advance.vi" is also broken there. I can't understand the problem.
Any suggestion is appreciatable.
Message 13 of 26
(4,904 Views)
Hi GerdW,
I don't know why "PID advanced.vi" is not working on my PC, even "PID advanced.vi" of the LabVIEW examples are not working. Always shows the same error message "broken". but only PID is working.
I didn't edit anything. and don't know how to find out specific broken place.
Message 14 of 26
(4,881 Views)
Hi Milon,
The first option is to mark the PID VI in the error window to read the error message specific to this VI.
The second step is to open the PID VI and to check it's block diagram…
Which LabVIEW version are you using? Which kind of license are you using?
Message 15 of 26
(4,878 Views)
Hi Milon,
You said you didn't modify those PID VIs - but the error shown will not pop up on its own…
Open the PID VIs and check their connector pane. It should look like this:
You will find the very same information in the LabVIEW help!
I can open both your VIs without any problem…
And PLEASE keep your discussion in one place! There is no need to create a new thread for the very same topic! (I moved your message into this thread…)
Message 16 of 26
(4,891 Views)
Hi GerdW,
I also can't identify the problem. Actually, the error shows for "PID Advanced.vi and PID Advanced autotuning.vi" only. other vi are ok. the connector pane is also ok. I have attached picture for clearing this matter.
Is there any other way without using this (PID Advanced) option?
Message 17 of 26
(4,872 Views)
What happens when you open the broken subVI?
The error is inside the PID VI...
Message 18 of 26
(4,864 Views)
Hi GerdW,
I have attached the pictures of very subVI under "PID Advanced.VI". Would you kindly check, please?
Message 19 of 26
(4,851 Views)
Hi Milon,
now you have shown the connector pane of the "DBL Array" type of the PID function.
As this is a polymorphic VI you also need to check the "DBL" variant of that PID function!
As the error said: "one of the polymorphic versions has a different connector pane and so the whole polymorphic VI is broken"…
Message 20 of 26
(4,844 Views)
