PID with Integer output
Hey guys, I'm trying to control a motor speed using Labview's PID toolkit
My issue is that my motor controller vi (MTR-CM) can only accept integer values within a range of 0 to 600 and I can't find a good way to limit what the PID control can output. I've attached demo code with an example of how the application would be implemented (Main.vi)
If anyone knows a good way to solve this, I'd greatly appreciate input.
(4,094 Views)
Scale your float to the appropriate integer range.
Ben
(4,087 Views)
Hi ATE,
Set the output range of the PID function to [0, 600] and apply RoundToNearest on the PID output:
(4,082 Views)
