PLC FESTO connect to LabVIEW
Hi!!
Please, help me!; I need connect a PLC FESTO FC660 with LabVIEW, I was Looking in DATABASE of OPC of National Instruments But I not Find FESTO, somebody, can I help me?
Best Regards
Message 1 of 12
(5,315 Views)
Hello qz6y7q,
Thanks for using NI forums! Unfortunatelly FESTO is not suppoerted directly by NI OPC server, what you need to do is communicate FESTO's OPC server with NI OPC server and then create the shared variables. Here is a link with all supported devices from NI OPC server.
http://www.ni.com/white-paper/6417/en/
Here's also a link that shows how to connect LabVIEW to a PLC using NI OPC Server.
http://www.ni.com/white-paper/7450/en/
Hope this information works for you!
Luis CT
Message 2 of 12
(5,263 Views)
Ok, Thanks.
Best Reagrds
Message 3 of 12
(5,240 Views)
hi qz6y7q , I have the same problem and I want to know if you have solved this problem, help me please
Best Regards
Message 4 of 12
(5,140 Views)
Hi!! Chimo.
Yes I Resolved the issue, in web page of FESTO download tha app IPC DATA SERVER, then run the aplication and configure the PLC FESTO, In the IPCs, after that, open NI OPC SERVER, use like DEVICE DRIVE " DDE Client Drive", then clic all next.
In Tag Config, use this Address:
To Flags, IPC_DATA|IPC_1!M5.1
To Inputs IPC_DATA|IPC_1!E0.0
somethig like SIEMENS
Inputs E0.0 bool, EW0, Integer
Outputs A0.0, Bool, AW0 integers
Flags, M0.0, Bool, MW0 Integers
so, the route to config address, IPC_DATA, means, the software IPC DATA servers, and IPC_1 means that you the PLC configure in IPC DATA SERVER in IPC 1.
PLease ,let me Know if working.
Best regards
Message 5 of 12
(5,133 Views)
If you have  other question, please clic this link
www.automation-inc.com.mx
Message 6 of 12
(5,129 Views)
hello, thank you very much for your reply, I have a PLC FESTO FC640, but I think I will proceed in the same way and for the link I found nothing in there that can help me
Best Regards
Message 7 of 12
(5,111 Views)
Hi Automatizate !
I did everything you said but it didn't work, I configured the Data Server IPC and I chose a new channel in the NI OPC => new device => new tag and I Quick launch OPC client, then I accessed to labview => my computer => New I / O server => OPC Client, but the communication has failed , please can you help me ?
Best Regards
Message 8 of 12
(5,079 Views)
Plzzz i need help !!!
Message 9 of 12
(5,027 Views)
Hi Chimo
I find you problem, just connect the PLC FESTO with LaVIEW V2010
If you use LabVIEW 2011 or latest not work
Message 10 of 12
(4,975 Views)
