PLEASE HELP!!!!! IMAQdx issues
Hi!
I'm trying to use IMAQdx to acquire images from a camera with a firewire connection. The camera shows up fine in MAX and I can grab images etc. But when I try to run a very simple program in Labview just to Snap an image the Error 1074360311 comes up with "Camera not found" as the reason.
I haven't specified an input for Open Camera but the default is set to cam0, which is what the camera comes up as in MAX. Does anyone know how to specify the name of the camera?
Any help would be greatly appreciated!!
Ciara.
(3,052 Views)
Are you sure the camera is associated with IMAQdx in MAX?
Can you post a screenshoot of the part of your VI where you open the reference to the camera?
Christian
(3,040 Views)
