Problem using IMAQdx, Error-1074360311
Hi!
I'm trying to use IMAQdx to acquire images from a camera with a firewire connection. The camera shows up fine in MAX and I can grab images etc. But when I try to run a very simple program in Labview just to Snap an image the Error 1074360311 comes up with "Camera not found" as the reason.
I haven't specified an input for Open Camera but the default is set to cam0, which is what the camera comes up as in MAX. Does anyone know how to specify the name of the camera?
Any help would be greatly appreciated!!
Ciara.
(3,186 Views)
(3,166 Views)
