PLEASE HELP IN FLIP FLOP !!
hi , i am a mechanical engineer new to labview and need help in creating a vi that can do the folowing flip flop function as shown in the attached dig .
please upload a vi if possible ..
Thank u
Avinash
IC Engines Lab
IIT Madras
(3,487 Views)
Accepted by avinash123
Your context is not clear at all.
iFor example, f it is a user input like a mouse click then your problem is easily solved by changing the mechanical action of boolean button. This link gives more information on that. https://www.ni.com/docs/en-US/bundle/labview/page/changing-the-mechanical-action-of-a-boolean-object...
Is it an external pulse signal plotted on a waveform? if so then it is an array format and you can use array functions to compare and activate a boolean indicator
please explain more about your problem.
He who asks a question is a fool for a minute.
he who does not, remains a fool forever.
(3,476 Views)
You've asked this question multiple times in several different boards:
http://forums.ni.com/t5/Multifunction-DAQ/Combination-Of-Two-Triggers/m-p/1622404
http://forums.ni.com/t5/Digital-I-O/PLEASE-HELP-IN-FLIP-FLOP/m-p/1627902
http://forums.ni.com/t5/Counter-Timer/PLEASE-HELP-IN-FLIP-FLOP/m-p/1627906
http://forums.ni.com/t5/Digital-I-O/PLEASE-HELP-IN-FLIP-FLOP/m-p/1628172#M14617
At this point I'm not even going to bother helping you if you feel like spamming the boards. Especially with a question that looks just like a homework problem.
(3,442 Views)
sorry guys .. did not know where exactly i was supposed to post it as i am pretty new to forums .. so decided to post it in multiple forums ..
(3,411 Views)
any way i got the answer to my flip flop question my self ... and need help with a counter .. does lab view have any predefied counter vi's that can count the number of pulses between 2 events ?
(3,410 Views)
Refer Example Program
(3,404 Views)
