PMEngine.dll and RadiantCommon.dll in labview
I use PMEngine.dll and RadiantCommon.dll in MATLAB and view images stored in .pmxm file.
Is there a way I can use PMEngine.dll and RadiantCommon.dll in LabView to use .dll file and import .pmxm file?
Nilesh
(1,789 Views)
Call a Dynamic Link Library (DLL) from LabVIEW
https://tmesystems.net/
(1,767 Views)
I did that, I don't see any function associated with .dll files.  However in matlab, I can use same files with its functions.
(1,757 Views)
Accepted by Nilesh_2023
Those DLL files might be actually .Net assemblies (the fact they don’t follow the 8.3 naming scheme makes it very likely even though there is no need for that restriction in modern Windows for classical DLLs).
Try to place a .Net constructor on a diagram, right click on it and select Browse, selecting your DLL file. Does it give you any classes to select?
Rolf Kalbermatter  My Blog
(1,739 Views)
Yes, I see functions associated with .dll.
(1,724 Views)
