PMU usage in cRIO
Hi!
I am working on Hardware implementation of PMU, Can anyone say what is the usage of cRIO in PMU module. and Is there any Labview module for that. please anyone suggest me/.
Surya S
Message 1 of 30
(6,539 Views)
What do you mean by "PMU" Phasor Measurement Unit?...please clarify.
Jack H.
Message 2 of 30
(6,496 Views)
Yes,Its Phasor Measurement Unit.
Message 3 of 30
(6,494 Views)
Hi suryas,
are you talking about this one?
What exactly do you have problems with?
Message 4 of 30
(6,485 Views)
yes exactly..
Message 5 of 30
(6,478 Views)
Hi suryas,
yes exactly..
Ok.
So I ask again: What exactly do you have problems with?
Message 6 of 30
(6,476 Views)
i just need to know why we are using cRIO for the PMU application and also i need to how to give sample time for cRIO in labview in FPGA interface mode.
Message 7 of 30
(6,471 Views)
Hi suryas,
Because YOU decided to use this hardware!?
Why should we know why YOU decided it this way?
In FPGA you create a loop to read inputs. Then you set a loop iteration time which will determine your sample rate…
Message 8 of 30
(6,469 Views)
Thanks for the answers
Message 9 of 30
(6,467 Views)
Loop iteration Time?
Message 10 of 30
(6,462 Views)
