PMU usage in cRIO
Hi suryas,
yes, loop iteration time: put a wait function in your loop and set the wait time…
Message 11 of 30
(1,790 Views)
Actually i am using 9201 analog input module. I am giving 3 V 50hz from the function generator, but in labview module am not getting that sine wave.
Message 12 of 30
(1,784 Views)
Hi suryas,
Then it seems you made something wrong!
It could be a problem in your wiring. Or it could be a problem in your VIs…
Solution: Check your wiring and your VIs!
Message 13 of 30
(1,778 Views)
This is my VI.
Message 14 of 30
(1,772 Views)
Hi suryas,
that's not a VI, that's an image…
Several notes:
- you should not use a chart in a FPGA VI: they FPGA does not support real monitors…
- you should not convert your FXP value into an integer value when you want to measure "analog" values…
- when you want to be able to change the sample rate while this VI is running you should move the control inside the loop: THINK DATAFLOW!
- you should use AutoCleanup more often…
Did you examine the example projects for RT and FPGA? They show you how to transfer data from FPGA to your RT/PC host…
Message 15 of 30
(1,766 Views)
Hi
Sorry that is an image only.
I dint see the sample projects. where can i find the sample projects.
If i want to see the analog values from 9201 waveform what should i do.
i just want to measure the analog values from the function generator (3 to 10 volt 50 HZ.) and want to display it in the front panel.
Can u suggest me some idea.
THANKS,
SURYA S
Message 16 of 30
(1,781 Views)
HI!
I am using cRIO 9075 and Input module 9201 for acquiring the analog input voltage from the sensor, but now i dont have the sensor so am using the function generator (3 v, 50 Hz). But in labview model i dint get the sin wave. In FPGA wave chart cant be used so is there any way that i can see the output values in waveform?
Surya S
Message 17 of 30
(1,801 Views)
Hi suryas,
File menu -> "New…"
Read the signal values in the FPGA.
Transfer the data to your RT host.
Display the data in the RT host.
When you need to data on your host PC: transfer the data from RT to PC and display/store them there.
There are example projects explaining how to do all this…
Edit:
Please don't create double threads for the very same topic!
I merged it with your current thread…
Message 18 of 30
(1,771 Views)
Please can you send any example VI's I am not able to find it.
Message 19 of 30
(1,745 Views)
Hi suryas,
example VIs are found in the example finder (see Help menu aof LabVIEW).
Example projects are found (as already mentioned above) in the File menu -> "New…" dialog!
Message 20 of 30
(1,738 Views)
