PWM PCI-6251
Hi,All
I am had a problem to create PWM in PCI-6251.
I am want the example to create PWM in PCI-6251.
thank you very much
zacha
Message 1 of 15
(5,486 Views)
Hi!
I used this way to do that.
By
Yann
Yann Falevoz
R&D Engineer, Instrumentation & Software
Message 2 of 15
(5,473 Views)
thank for your reply
Message 3 of 15
(5,458 Views)
Hello zacha,
You may also want to take a look at the NI-DAQmx example program titled PWM-Counter Output.vi.  This example program can be found in the LabVIEW Example Finder (Help > Find Examples) by searching for the term PWM.  I would also recommend browsing the online example program database at www.ni.com/examples.
Travis G.
Applications Engineering
www.ni.com/support
Message 4 of 15
(5,440 Views)
thanks Travis G. for your reply.
i am look in example program .it is counter output display but it not digital output (PWM) display.
i am use PCI-6251 to measument position and pressur sensor and create PWM to drive soleniods valve.
i am want digital output (PWM) are very duty cycle.
plaese example program to digital output(PWM) and show graph display
Best regard,
zacha
Message 5 of 15
(5,435 Views)
Hello Zacha,
A quick search of www.ni.com/examples with the keywords 'PWM' and 'digital' produced the following result:
NI-DAQmx: M Series Digital Channel Pulse Width Modulation (PWM)
I hope this helps,
Travis G.
www.ni.com/support
Message 6 of 15
(5,417 Views)
Hello Travis G.
I am search of www.ni.com/examples with the keywords 'PWM' and 'digital' produced the following result:
and i use it ,i set duty cycle = 20% but it generate the 64% duty cycle in th first three pulse.
i don't want the first three pulse .How i do
best regard
zacha
Message 7 of 15
(5,302 Views)
Hi zacha,
I tested that VI and got the same behavior that you were seeing.  The reason why it is generating the first 3 pulses with 64% duty cycle is because the digital output task is initialized with a generic data array that makes up a waveform with this duty cycle.  I have modified the VI to initialize with a waveform that has the preferred duty cycle.
Andrew W
Message 8 of 15
(5,287 Views)
Hello Andrew W
Thanks for your reply. i am don't open this program because i use labview 8.0 student edition.
How i do.
Best regard
zacha
Message 9 of 15
(5,273 Views)
Hi zacha,
Here's the same VI saved in LabVIEW 8
Andrew
Message 10 of 15
(5,272 Views)
