Hello LV_junkie
Thanks for yous reply.i'm sory. i'm not clear the problem in my program.
In my program .i'm use DAQ Assistant measurement the analog input from position sensor and calculate the positon in degree.
i'm use the position (deg) to check condition in case structure. the program in case structure [1] are generate the PWM to drive
the solenoid valve.
the fomula are check the condition in case structure is:
//condition to Position//
/* a is an input from position sensor and b is a insirt position input */
/* y = 0 decrease angle
y = 1 increase angle
y = 2 hold position */
if (a[0]>=b) /* if array a[0] >= input*/
y=0; /*y is default condition =0*/
else y=1; /*if array a[0] < input .y is codition =1 are increase position angle*/
if ( abs(a[0]-b) <=5)
y=2;
The problem in my program is:
1.When generate the PWM in port0/line0:7 the DAQ are not measurement a analog input in real time.
but it measurement a one value only.
2.It not calculate the position (deg) to check condition in case structure becuase it not real time.
In my program i'm want twice the measurement in real time and generate the PWM to drive solenoid valve.
How i do
Best regard
zacha
