PXEe-7847R Support in LabVIEW 64
I noticed that if I run LabVIEV 2019 (32-bit) the PXIe-7847R is supported as a target.  If I run LabVIEW 2019 (64-bit) the PXIe-7847R is not supported.  Is the PXIe-7847R library not  supported in 64-bit?
(1,563 Views)
I assume you added LV 64-bit after you added your drivers?  You need to reinstall all your drivers to make them aware of the new LV installed.  You need to reinstall the drivers every time you add a new flavor or version of LabVIEW.
Bill
CLD
(Mid-Level minion.)
(1,525 Views)
Bill,
Yes I loaded all the drivers again after loading LabVIEW.
Paul
(1,510 Views)
