Psoc 5lp programming using LabVIEW acticex
Hi all
I have one assembled PCB with with cypress psoc device CY8C5268AXI, I want to program (flash load) this device using LabVIEW active x.
Pls help in this regards
TIA
Regards
Shashidhara HB
(2,430 Views)
Hi Shashidhara,
Read the manual of your PSoC and the software, that comes with it. Then implement the needed steps in LabVIEW…
(2,423 Views)
I am struggling with that, if any body has done this  pls share
(2,407 Views)
Hi Shashidhara,
What have you tried so far?
Where are you stuck?
Why don't you attach your VI and (a link to) a manual of your PSoc?
Why do you want to use LabVIEW for this task?
Why do you ask for ActiveX usage?
(2,404 Views)
