PXI 1078 internal trigering between cards
Hi all,
I want to use the internal trigering of the PXIe 1078 chassis. I have been reading online about the internal trigers in PXI and in my case I have PXI_Trig0 to PXI_Trig7. my setup is as follow I am using a PXI 6535 DIO card in slot 2 and 6115 Analog card in slot 4. I would like to generate an internal trigger using the back plane of the PXIe1078 chasis when I want PXI 6115 card to start acquiring data. Currently I am using the Triger from outside. The whole idea is to have an internal trigger within the back plane on chassis to remove the need of an external trigger.
A little bit about the process flow I send Digital data from 6535 card to a sensor and as soon as i send this data I would like to send the trig to the 6115 card through the back plane to start acquiring. I am still not able to figure out the programming part of how to use the back plane trigger using labview.
Best Regards
Regards
(3,220 Views)
Accepted by topic author nolsqn
(3,156 Views)
