PXI 5422 Trigger output control
How can the trigger output of the Digital Data and Control be controlled?
Can it produce either a trigger pulse or digital value change on one of the PFI outputs through software instead of just at the start of the generation?
(2,940 Views)
Could you explain a little more about your application and what you are trying to achive,  as well as what events you want your trigger to be output on?  What is this tigger going to be driving?
Matt Surridge
(2,863 Views)
