PXI 6514 SCB-100 Help
hi all,
I tried many times to get a Digital Out from that box. But without any success.
I have a board with i need to pull 32 Pionts down to zero. And I have PXI 6514 SCB 100 and PXI 6733 SCB 68.
I made it at the 6733 to bring a signal out of the digital outs, but at the 6514 happens nothing!
Can someone help me???
(3,858 Views)
When i set the switches in the passthrough mode (S6 up, S5 down, S4 down, S1 rigth, s2 right, S3 right) all pins passthrough (Pin1 = Pin1...Pin100=Pin100)
Is that the only way to get all the 32 in/out Ports of the 6514 to the board????
I testet sometimes: for example GND to Pin 96 and 5V+ to Pin 97. Then i measure on Pin 95.
When i put the line 7 of port 7 to low i measure 2Volt and at high i measure 5Volt. That seems to be a bit correctly.
But should there not be 0V when i set it on LOW???? Or where from could that 2V be?
I dont know, what to do...
can someone help me??? or just give me some info?
best reguards
Simon
(PS: Könnte ich den auch deutsch reden, wenn möglich? Bin bei Englisch nicht so konform ^^)
(3,850 Views)
hmmm...k it works now...but at the Digital Input i need to have a signal of min. 6V
I thought that a high level of 5V is enough! And that starts at 2,3V its a high.
Works the card 6514 with a 24V level???
(3,846 Views)
