PXI-6534 Card using Traditional Legacy Card to DAQmx driver
I don't know where to start..I am stuck on an issue that needs to be solved.
I am using a Traditional legacy driver on a PXI-6534 Card.
 I want to move it to using the DAQmx driver.
Can someone point me to the right direction?
Thank you..
Krispiekream
(3,079 Views)
Start here
(3,077 Views)
i read over the link you provided and i can see that changing it will take a while.
 some of the examples given didn't cover all the questions i have.
can you see my vi and see how would i change that to daqmx?
Message Edited by krispiekream on 02-24-2009 03:34 PM
Krispiekream
(3,064 Views)
That's done with the DAQmx Create Channel. You select the digital type that you want (write or read) and specify the channels.
(3,058 Views)
i dont know if i am doing this right or wrong, but i am getting this ...
Message Edited by krispiekream on 02-24-2009 04:09 PM
Krispiekream
(3,053 Views)
The first thing to check is like the error message says and see if it is reservered by the traditional DAQ driver. Reet that and verify you can see the device in MAX with the test panels for DAQmx.
(3,034 Views)
