PXI-8232
I am trying to get a PXI-8232 (GPIB and ethernet) card to work mounted in a PXI-1045 chassis.  I have installed the latest drivers, but the card still does not show up in MAX.
I am fairly sure that the physical connections are all sound, because I have successfully tested the ethernet connection of the card.
Any ideas welcome, although I am a complete LV novice so please dumb it down!
(3,576 Views)
Have you powered on the PXi chassis before powering up the PC.
The PXI chassis acts like a PCI device in your PC and should be powered all the time the PC is powered on.
André
André (CLA, CLED)
(3,568 Views)
Yes, the chassis has been powered up the whole time.
I have no problem seeing the chassis in MAX, and all the other PXI cards show up too.  It is just the PXI-8232 which does not show up.  I am convinced the electrical connections are fine, as the ethernet port on the card does work.
(3,565 Views)
Duplicate post.
In the other thread, which I've been following, rich_s has been giving you good advice, and posting the same issue again without a reference to the original thread causes people to regurgitate the same advice.
(3,552 Views)
Not to mention this thread as well.
Please stop posting about the same problem in multiple threads.
(3,549 Views)
