09-22-2021 01:50 AM
NI-5124 PXI oscilloscope failing.
MAX can´t recognize the type of the PXI bridge, but it is a PXI-MXI-4 (PCI-8336 and PXI-8336)
These error codes indicate fairly general problems that can be caused by either hardware or software. You can resolve these errors through one of the troubleshooting steps below:
I have tried 1, 2 and 3 => did not help. About 1 Reset and Self-test is success but Self- Calibrate is just running for ever.
@4 If this was not setup correctly, I assume the PC would not be able to see the PXI rack and modules in it.
What could be my next step?
Tanks in advance
/Bjarne
09-23-2021 07:27 AM
Hi
Update: I have tried to delete all labview and device driver Sw on the PC and then installed it again.
I still got the same error!
/Bjarne
09-23-2021 11:21 PM
Hi
Update:
Started Self Calibration yesterday afternoon This morning I gt this error in MAX:
/Bjarne
11-09-2021 09:51 AM
From the error it seems you may have compatibility issues. Have you checked your system for that?
11-09-2021 11:27 PM
Hi
Sorry the late response.
I have been spoken to a NI engineer and it looks like combability problem with the MXI card. It's not supporting Win10.
I have ordered new MXI card and I'll went back when I get the new card and I know it has solved the problem. Hopefully ultimo November.
Regards Bjarne
