PXI6683
When I insert the active antenna into the PXI 6683H,I can receive the time and see it in MAX but it is local time.How can i change the local time to UTC? And I also want to know how to program that i can see the time from the front panel.
Thank you all!
(2,931 Views)
(2,898 Views)
Thank you very much,but it seems that this article can not help me to solve this problem.
Can you tell me more suggestions?
(2,882 Views)
Accepted by yangmie
My apologies, I don't really understand what you meant by changing time to UTC? Does it mean that you want to change your clock to a different time zone?
If you want to change the time in NI-MAX, you can change your time zone from the control panel >> Clock language, region >> Date and time >> Change the time zone
(2,878 Views)
