Packed library file paths
I have been using packed project libraries for a while on a project with no problems.
From an executable I run a VI in this packed lib dynamically with a relative path. This has been working perfectly.
All of a sudden, it has stopped working because the 'path' in the project lib has the entire folder tree replicated. I don't know what has changed to make this happen. I have also reverted to a much older version of the project but get the same symptoms implying something has changed in the LabVIEW IDE.
For example, before if my packed lib was stored in
A:\project\LabVIEW\builds\Client UI Packed Lib.lvlibp
the tablet UI Loaders path would be in
A:\project\LabVIEW\builds\Client UI Packed Lib.lvlibp\Tablet UI Loader.vi
The behaviour I am seeing now, which is also shown in the screenshot, is that the tablet UI loader has the following path
A:\project\LabVIEW\builds\Client UI Packed Lib.lvlibp\A\project\LabVIEW\builds\Client UI Packed Lib.lvlibp\Tablet UI Loader.vi
As you can see the entire folder tree is replicated.
Anyone have any suggestions as to what setting may have changed for this to be happening now?
(3,808 Views)
It looks like somebody did "Something Wrong (tm)" in the SCC repository.
I recommend retraining for the individual using negative reinforcement
(3,799 Views)
Accepted by Worle
It looks to me that the PPL was built with a VI being called from another drive.  I would guess you got a cross-contamination with another project.
(3,781 Views)
Correct. After tidying up the project dependencies I found one VI which was being called from another projects directory.
Fixing that solved my problem.
What I am a little confused about is why LabVIEW was looking there in the first place. Also I am confused as to why reverting to an old version didn't solve this issue, especially seeing as the revision I reverted to was before the other project was even started
(3,740 Views)
Vis in memory is a high priority default search path.  This makes "Flossing" your lvproj a bit more painful when some developer does "Something Wrong (tm)" in SCC.
The standard slap of the female canine variety is a useful negative reinforcement training tool.
(3,730 Views)
