Padding a julian date with leading zeros ?
I have gernerated a julian date, which I am appending to another two digit number to create a five digit serial number.
Is there a simple way to pad the first 99 days with leading zeros ( i.e. 001, 002....025...099) so that I maintain a five digit serial number ?
I am using   Get Date In Time/Seconds > Number To Decimal String > Unbundle >Number to Decimal String.
Thank you in advance for any advice,
Alan
(4,119 Views)
You've got me confused as to what you mean by Julian calendar and days going up to 99.  I thought the Julian calendar was the one that was used from Roman times until about 1700's.
To get a 3 digit string, use the Format Into String function where the format string is %03d   That will create a 3 digit number with zeroes padded on the left.
Message Edited by Ravens Fan on 02-20-2008 11:51 PM
(4,116 Views)
The Julian day is the number of the day in the current year.
(4,110 Views)
Here's the simplest way to do it (with he 2 digit number), I believe:
Message Edited by Matthew Kelton on 02-21-2008 12:43 AM
(4,106 Views)
Yes %<%j>T always returns the current day in 3 digits.
See here
Ton
My LabVIEW Ideas
(4,095 Views)
Many thanks for the responses ! I was able to create the desired string.
Alan
(4,062 Views)
