Parallel Analog Input DAQmx
Accepted by kepham
The event structure can be triggered by front panel controls, some panel interactions (like mouse movements), and dynamically through "user events".
It might be easier to wrap your head around notifiers / queues. The example below works because when "wait on notification" times out, it returns the default boolean value, false. When you want the loop to stop, send a value of true.
Message 11 of 12
(949 Views)
Thank you so much!
Message 12 of 12
(927 Views)
