Parallel Execution of VIs in LabVIEW
     I want to parallely execute 3 VIs simultaneously.  I have used a global variable to trigger event in 3 VIs. But the input from 1st VI is used as the ouput for 2nd one. So the 2nd VI is waiting for 1st VI to complete. How to overcome this problem? The input is an array variable. I want ot execute the 2nd VI for each row updation of array from 1st VI.
Please give a solution
Message 1 of 20
(8,076 Views)
Hi rakesh,
To let the 2nd VI execute AFTER the 1st VI you should use DATAFLOW by wires!
When you really want to execute them in parallel but still have 2nd wait for 1st you should use a queue (producer-consumer scheme)…
Message 2 of 20
(8,073 Views)
I want to run three VIs in parallel. One VI will generate a set of data (say 1 row of 2D array in each iteration). The 2nd VI will do some processing  in the first row and calculate result and update the data structure.. The third VI has to display this and log to a text file. 3rd VI will then wait for 2nd row to update. The three VIs has to run parallel.
Please tell a solution for the above problem ?? . Also which data structure I have to use for sharing data between VIs?Thanks in advance
Message 3 of 20
(8,059 Views)
Hi rakesh,
what's your reason to start a new thread for the same topic - after you got an answer?
Use a producer-consumer scheme.
Why do they need to run in parallel when they have to wait for each other???
Data structure depends on your data…
Message 4 of 20
(8,054 Views)
Definitely look at the Producer/Consumer.  The idea is to use queues to send the data from one loop to the next.
Message 5 of 20
(8,023 Views)
Ok. thanks.
How can I share data between two VIs other than global variable?.
Producer consumer means through queue message handler?
Message 6 of 20
(8,020 Views)
My data generation is in one VI and processing is in another VI. So how can I exchange data using message queues?
Message 7 of 20
(8,017 Views)
did you have a look at the link for the producer-consumer pattern?
did it answer your question?
have you tried to implement the pattern in your own VI?
do you have problems? do you have code to show your problem?
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 8 of 20
(8,012 Views)
Thanks for the reply.Yes I have.
But the problem is I have to use two VIs. One will generate data in loop and another Vi has to get this data and do some processing and display to the main GUI. For the literature and NI template I got a single VI for production nad consumption. How to implement it in two VIs. Please help
Message 9 of 20
(8,004 Views)
Hi rakesh,
implement a producer-consumer scheme.
LabVIEW comes with ready-to-use example projects, (atleast) one of them shows a typical producer-consumer setup!
What have you tried? Where are you stuck? What is your problem?
Message 10 of 20
(7,999 Views)
