Parallel port printing no longer works in WinXP
I have been using Zebra HT-146 barcode printers(parallel port) with Win2000 without problems, but when I moved my application to another PC with WinXP, my print VIs no longer work.
I have verified that the printer and cables work 100% on Win2000 PC.
Thanks for any suggestions.
Dave
(2,576 Views)
I have head of issues with winXP printer drivers. Here is the latest that I could find from Zebra. Driver version on their website is 5.3.5.15.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/ht146.4.tabs.html
(2,557 Views)
I found the solution, but not the root cause. I did install the newest WinXP driver from Zebra but it did not change anything. The only thing that did make a difference was to go into Start>Settings>Printers and delete the Zebra printer. Then it worked fine. Go figure!
Dave
(2,546 Views)
