06-15-2020 05:37 AM
How to build a pareto chart in labview?
06-15-2020 06:09 AM - edited 06-15-2020 06:09 AM
Hi sibangi,
to show a pareto chart you simply have to sort your data values to start with largest value first.
Then plot them in a graph and edit the plot properties to show bars…
06-15-2020 06:45 AM
But for Pareto analysis, the cumulative frequency is taken into account and also there is another line chart along with the bar chart. how to do that?
06-15-2020 06:48 AM
Hi Sibangi,
You can prepare your data as you like. When you need some cumulated values then you need to add them up…
A graph can show more than just one plot. Each plot can have ite own plot properties!
06-15-2020 12:40 PM
the tricky part will be to label each column properly
annotations may be used...
03-10-2022 05:15 AM
Hi Alexderjuengere
Could you please share your VI? Because I can not find Notizliste property node and I also don't know how to create it.
03-10-2022 08:20 AM - edited 03-10-2022 08:21 AM
In English versions that is the Annotations property
03-10-2022 10:04 AM
attached as.vi saved backed to labview 2010 (64 bit)
correct
06-11-2026 01:58 AM
In case of single run, the annotations are clear and visible, but if the acquisition is continuous, then when maximum in Y axis data gets higher and then that compresses the Y scale values and the annotation gets overlapped with the bar plot data and gets hidden, any idea on how to handle this scenario?
06-11-2026 08:30 AM
scale your data to 1, before displaying in a pareto chart
