Parse XML string NXG4
Dear Community members
I am in the process to use NXG more and more (NXG 4)
Now I had to convert some code where I used the parse XML features from LabVIEW 20xx.
I there any equivalent to parse XML in NXG 4. The code conversion tool was not able to do anything with this sub vi's.
Thank you for any input
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
Message 1 of 9
(6,053 Views)
This will not help you a lot but, I asked JKI (on their forum) they intend to publish thier XML tools for NXG in 2020. I know... that's a bit vague. Until then, I don't know what to suggest.
Good luck!
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 9
(6,044 Views)
I have no confidence this step helps you. We can use following example to read xml fast.
Libxml2: Parsing XML in LabVIEW is too slow... or is it?
The components call dll. NXG 4.0 also can. Can we convert the example to NXG version?
Certified LabVIEW Developer
GCentral
Message 3 of 9
(6,027 Views)
I have already fighted with libxml2 a few years ago. There was a problem with 64bit compatibility.
So I went to use the .NET xDocument solution which worked fine.
Sorry but I don't want to start again with the libxml solution.
Thank you for your suggestion
Gernot Hanel
Message 4 of 9
(5,966 Views)
Hi Gernot,
We have not yet migrated the native XML API but at least adding the flatten/unflatten VIs is on our roadmap. As mentioned above we'll be working with JKI to support their add-on migration for additional functionality over the coming year.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
Message 5 of 9
(5,920 Views)
Any news about migrating native XML to NXG now, Deborah? Will it be included in version 5.1 or 6? I think it is quite strange not to have XML support in a common programming tool. We have been using the XML parser in LabVIEW for many years, in fact since the Internet Toolkit was introduced, so lack of support for XML is really a problem for us when we consider switching to NXG. And the proprietary toolkit from JKI is not a replacement.
Message 6 of 9
(5,414 Views)
I advise to read the sticky posts at the top of the forum.  LabVIEW NXG is being discontinued.  The last version will be 5.1, due next year.
Bill
CLD
(Mid-Level minion.)
Message 7 of 9
(5,396 Views)
We have a requirement to parse an XML String to a complex business object.
Scenario : XML String was formed as a result of conversion of my complex business object. After changing values of some variables (to rectify application error), we need to parse this XML String back to the same complex business object.
Could someone provide your inputs on how to get this done using IBM BPM 8.5.x?
myccpay
Message 8 of 9
(5,323 Views)
There was an issue with 64bit similarity. So I went to utilize the .NET xDocument arrangement which turned out great.
Message 9 of 9
(5,321 Views)
