Parsing Scalar JSON from HTTP Client
Hello all, I have been using the HTTP Client to call an API via HTTP GET in order to receive a JSON string.  I want to be able to parse out all the information and data that I get in this JSON string.  I believe the JSON string I receive is a JSON Scalar and not an array or object.  It looks like a combination of array and object.  Here is an example of the data I get back:
{"measurements":[{"voltageRMS":120.12,"currentRMS":11.85,"totalEnergy":121044.295}],"code":"OK","duration":7}
I tried using "unflatten from JSON" however it did not work.  I kept on getting multiple errors.  Error 1 was that path cannot be found in JSON when I put in currentRMS as an array string in the path even though I am following the help directions.  Error 2 is that I have a different data type between JSON and LabView.  In one of the LabView examples, there is a JSON array going to multiple unflatten from JSON and it works just fine (as long as it's a JSON array).  However, once I use my JSON Scalar, the unflatten from JSON function no longer works.
So I downloaded some addons and used the JSON API from LAVA.  I used the JSON API for Scalar but kept on getting errors.  One of those errors is that the vi is unable to parse data.  I tried this with multiple parsing vi's (i.e. timestamp).  I tried using JSON array and got errors as well.
I am completely stuck, any advice would be greatly appreciated.  Please help.  Thank you.
(6,533 Views)
What was the LabVIEW datatype you tried to turn the JSON into?
It looks like you have a cluster containing three items: an array of clusters (which in turn contains three numeric items), a string and a numeric.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(6,498 Views)
Accepted by topic author DRH
Even though you only have 1 item in the array, the 'measurements' field is a JSON array - denoted by square brackets. Remember - the cluster needs to match the structure of the JSON data you are trying to decode exactly (not the format you are hoping for!).
With Unflatten From JSON - you can either convert the entire JSON string, or you can pull out items individually by path (e.g. like an XPath in XML).
Here's a couple of examples:
In the top example - I unflatten the entire cluster and this will give an array of measurements. In the second example, I only pull out the "0th" element from the measurement array as a scalar. Had I not added the '0' into the path array, the data type / output would have been an array of measurements.
(blog)
(6,484 Views)
Thank you so much Sam.  Much appreciated.
(6,461 Views)
