Pass Data between while loops
I've two loops and just need to pass some values (say 3-4 values) from main loop to secondary loop only once. What is the best way to do it?
Thanks in advance.
(4,657 Views)
Accepted by PadmanabanJ
Hi Padma,
use locals, globals, notifier, channels, ...
Put those items in a (typedefined) cluster to ease handling.
(4,645 Views)
How about using Queues?
(4,632 Views)
Please define "only once".  Do you want the second loop to just use the latest value for a variable(s) that the first loop wrote or do you want to send a message to the second loop to update some state information?  In the first scenario, I would use global variables.  In the second scenario, I would use a Queue or User Event.
(4,623 Views)
